주요 콘텐츠로 건너뛰기
Sony BDP-S1 Button Replacement
필요한 것
  1. Sony BDP-S1 Button Replacement, Sony BDP-S1: Getting inside the device: 1 단계, 이미지 2개 중 1개 Sony BDP-S1 Button Replacement, Sony BDP-S1: Getting inside the device: 1 단계, 이미지 2개 중 2개
    • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
    • Don't forget, there are two more 12mm screws on the other side as well.
  2. Sony BDP-S1 Button Replacement: 2 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 2 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 2 단계, 이미지 3개 중 3개
    • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
    • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
    • Lastly, remove the three 12mm black screws on each side of device.
  3. Sony BDP-S1 Button Replacement: 3 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 3 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 3 단계, 이미지 3개 중 3개
    • Potential for device damage: Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
    • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
  4. Sony BDP-S1 Button Replacement: 4 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 4 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 4 단계, 이미지 3개 중 3개
    • After the top is off, you'll see that there are two metal bars that go across the top of the device.
    • Remove each bar by unscrewing the two 10mm silver screws on each end.
  5. Sony BDP-S1 Button Replacement, Front Panel Buttons: 5 단계, 이미지 1개 중 1개
    • Now, on the front panel, you will want to remove the two 10mm screws on top of the device.
  6. Sony BDP-S1 Button Replacement: 6 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 6 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 6 단계, 이미지 3개 중 3개
    • Place your blu-ray player so that it's facing the ceiling and support it with your non-dominant hand.
    • With your screwing hand, use the plastic opening tool to gently undo the three clips on the bottom of the device.
    • Then put the device back down and undo the two clips on the side.
  7. Sony BDP-S1 Button Replacement: 7 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 7 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 7 단계, 이미지 3개 중 3개
    • On the top of the panel, use the plastic opening tool to unhook the top two clips.
    • Now the front should be detached so you can remove the front panel from the rest of the device.
  8. Sony BDP-S1 Button Replacement: 8 단계, 이미지 2개 중 1개 Sony BDP-S1 Button Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the ribbon cable found on the front panel by gently pulling at the base of the cable at each end.
    • NOTE: In these photos, the disk drive is removed. You don't have to remove the disk drive during this particular guide.
  9. Sony BDP-S1 Button Replacement: 9 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 9 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 9 단계, 이미지 3개 중 3개
    • Finally, remove the two 10mm screws on the front.
    • Congratulations! You have taken out the front panel!
결론
작성자
2다른 기여자 명과 함께
Mac
회원 가입일: 01/26/14
107 평판
안내서 1개를 작성함
Cal Poly, Team 9-30, Maness Winter 2014 Cal Poly, Team 9-30, Maness Winter 2014 회원
CPSU-MANESS-W14S9G30
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 747
