주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony BDP-S1 Button Replacement
필요한 것
    1. Sony BDP-S1 Button Replacement, Sony BDP-S1: Getting inside the device: 1 단계, 이미지 2개 중 1개 Sony BDP-S1 Button Replacement, Sony BDP-S1: Getting inside the device: 1 단계, 이미지 2개 중 2개
      • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
      • Don't forget, there are two more 12mm screws on the other side as well.
      댓글 쓰기
    2. Sony BDP-S1 Button Replacement: 2 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 2 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 2 단계, 이미지 3개 중 3개
      • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
      • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
      • Lastly, remove the three 12mm black screws on each side of device.
      댓글 쓰기
    3. Sony BDP-S1 Button Replacement: 3 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 3 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 3 단계, 이미지 3개 중 3개
      • Potential for device damage: Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
      • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
      댓글 쓰기
    4. Sony BDP-S1 Button Replacement: 4 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 4 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 4 단계, 이미지 3개 중 3개
      • After the top is off, you'll see that there are two metal bars that go across the top of the device.
      • Remove each bar by unscrewing the two 10mm silver screws on each end.
      댓글 쓰기
    1. Sony BDP-S1 Button Replacement, Front Panel Buttons: 5 단계, 이미지 1개 중 1개
      • Now, on the front panel, you will want to remove the two 10mm screws on top of the device.
      댓글 쓰기
    2. Sony BDP-S1 Button Replacement: 6 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 6 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 6 단계, 이미지 3개 중 3개
      • Place your blu-ray player so that it's facing the ceiling and support it with your non-dominant hand.
      • With your screwing hand, use the plastic opening tool to gently undo the three clips on the bottom of the device.
      • Then put the device back down and undo the two clips on the side.
      댓글 쓰기
    3. Sony BDP-S1 Button Replacement: 7 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 7 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 7 단계, 이미지 3개 중 3개
      • On the top of the panel, use the plastic opening tool to unhook the top two clips.
      • Now the front should be detached so you can remove the front panel from the rest of the device.
      댓글 쓰기
    4. Sony BDP-S1 Button Replacement: 8 단계, 이미지 2개 중 1개 Sony BDP-S1 Button Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the ribbon cable found on the front panel by gently pulling at the base of the cable at each end.
      • NOTE: In these photos, the disk drive is removed. You don't have to remove the disk drive during this particular guide.
      댓글 쓰기
    5. Sony BDP-S1 Button Replacement: 9 단계, 이미지 3개 중 1개 Sony BDP-S1 Button Replacement: 9 단계, 이미지 3개 중 2개 Sony BDP-S1 Button Replacement: 9 단계, 이미지 3개 중 3개
      • Finally, remove the two 10mm screws on the front.
      • Congratulations! You have taken out the front panel!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Mac
회원 가입일: 01/26/14
107 평판
안내서 1개를 작성함
Cal Poly, Team 9-30, Maness Winter 2014 Cal Poly, Team 9-30, Maness Winter 2014 회원
CPSU-MANESS-W14S9G30
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 42
전체 시간: 1,062
