주요 콘텐츠로 건너뛰기
Sony BDP-S3700 Motherboard Replacement
필요한 것
  1. Sony BDP-S3700 Motherboard Replacement, Front Panel: 1 단계, 이미지 1/2 Sony BDP-S3700 Motherboard Replacement, Front Panel: 1 단계, 이미지 2/2
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Motherboard Replacement: 2 단계, 이미지 1/2 Sony BDP-S3700 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Motherboard Replacement: 3 단계, 이미지 1/2 Sony BDP-S3700 Motherboard Replacement: 3 단계, 이미지 2/2
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Motherboard Replacement: 4 단계, 이미지 1/1
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Motherboard Replacement, Disc Drive: 5 단계, 이미지 1/3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: 5 단계, 이미지 2/3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: 5 단계, 이미지 3/3
    • Flip the Blu-ray back up
    • Remove the three ribbon cables that connect the disc drive to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Motherboard Replacement: 6 단계, 이미지 1/2 Sony BDP-S3700 Motherboard Replacement: 6 단계, 이미지 2/2
    • Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
  7. Sony BDP-S3700 Motherboard Replacement: 7 단계, 이미지 1/1
    • Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
  8. Sony BDP-S3700 Motherboard Replacement, Motherboard: 8 단계, 이미지 1/2 Sony BDP-S3700 Motherboard Replacement, Motherboard: 8 단계, 이미지 2/2
    • Gently pull upwards on the ribbon cables to disconnect the motherboard from the Wi-Fi module and port board.
  9. Sony BDP-S3700 Motherboard Replacement: 9 단계, 이미지 1/3 Sony BDP-S3700 Motherboard Replacement: 9 단계, 이미지 2/3 Sony BDP-S3700 Motherboard Replacement: 9 단계, 이미지 3/3
    • Remove the three 7mm screws along the motherboard using a PH1 screwdriver.
  10. Sony BDP-S3700 Motherboard Replacement: 10 단계, 이미지 1/3 Sony BDP-S3700 Motherboard Replacement: 10 단계, 이미지 2/3 Sony BDP-S3700 Motherboard Replacement: 10 단계, 이미지 3/3
    • Remove the 4mm screw above the HDMI port and the 9mm screw Digital Out port.
  11. Sony BDP-S3700 Motherboard Replacement: 11 단계, 이미지 1/1
    • Carefully lift and pull the motherboard forward to remove.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Luiz Barreto
회원 가입일: 02/15/17
627 평판
안내서 5개 작성하였습니다
USF Tampa, Team 12-1, Eyestone Spring 2017 USF Tampa, Team 12-1, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G1
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Thanks for the guide really good! Does anyone know where i can get a sony bdp-s3700 motherboard replacement?
James Durham - 답글
Same problem here.
Julian Robbins -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 1,446
