주요 콘텐츠로 건너뛰기
Sony BDP-S3700 Port Board Replacement
필요한 것
  1. Sony BDP-S3700 Port Board Replacement, Front Panel: 1 단계, 이미지 1/2 Sony BDP-S3700 Port Board Replacement, Front Panel: 1 단계, 이미지 2/2
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Port Board Replacement: 2 단계, 이미지 1/2 Sony BDP-S3700 Port Board Replacement: 2 단계, 이미지 2/2
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Port Board Replacement: 3 단계, 이미지 1/2 Sony BDP-S3700 Port Board Replacement: 3 단계, 이미지 2/2
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Port Board Replacement: 4 단계, 이미지 1/1
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Port Board Replacement, Port Board: 5 단계, 이미지 1/1
    • Flip the Blu-ray back up
    • Remove the ribbon connecting the port board to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Port Board Replacement: 6 단계, 이미지 1/1
    • Use the PH1 to remove the 7mm screw on the port board.
  7. Sony BDP-S3700 Port Board Replacement: 7 단계, 이미지 1/1
    • Remove the port board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Luiz Barreto
회원 가입일: 02/15/17
627 평판
안내서 5개 작성하였습니다
USF Tampa, Team 12-1, Eyestone Spring 2017 USF Tampa, Team 12-1, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 1,036
