주요 콘텐츠로 건너뛰기
Sony BDP-s7200 Front Panel Cover Replacement
필요한 것
  1. Sony BDP-s7200 Front Panel Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the disk tray cover from the device.
  2. Sony BDP-s7200 Front Panel Cover Replacement: 2 단계, 이미지 1/2 Sony BDP-s7200 Front Panel Cover Replacement: 2 단계, 이미지 2/2
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
  3. Sony BDP-s7200 Front Panel Cover Replacement: 3 단계, 이미지 1/2 Sony BDP-s7200 Front Panel Cover Replacement: 3 단계, 이미지 2/2
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
  4. Sony BDP-s7200 Front Panel Cover Replacement: 4 단계, 이미지 1/1
    • Pull off the back panel and remove it from the device.
  5. Sony BDP-s7200 Front Panel Cover Replacement, Front Panel Cover: 5 단계, 이미지 1/3 Sony BDP-s7200 Front Panel Cover Replacement, Front Panel Cover: 5 단계, 이미지 2/3 Sony BDP-s7200 Front Panel Cover Replacement, Front Panel Cover: 5 단계, 이미지 3/3
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
  6. Sony BDP-s7200 Front Panel Cover Replacement: 6 단계, 이미지 1/2 Sony BDP-s7200 Front Panel Cover Replacement: 6 단계, 이미지 2/2
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
  7. Sony BDP-s7200 Front Panel Cover Replacement: 7 단계, 이미지 1/3 Sony BDP-s7200 Front Panel Cover Replacement: 7 단계, 이미지 2/3 Sony BDP-s7200 Front Panel Cover Replacement: 7 단계, 이미지 3/3
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
  8. Sony BDP-s7200 Front Panel Cover Replacement: 8 단계, 이미지 1/2 Sony BDP-s7200 Front Panel Cover Replacement: 8 단계, 이미지 2/2
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mitchell Novak
회원 가입일: 01/16/20
778 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 196
