소개
Use this guide to remove the cassette compartment of your camcorder.
필요한 것
Orient your Betamovie so that the back of the device is sitting flat, and the bottom of the device is facing you.
Slide the RELEASE switch up to bring the hand drip down.
Remove the two screws (2mm x 6mm) at the base of the Cassette compartment using the Phillips #1 screwdriver.
Remove the two screws (2mm x 6mm) at the back of the Betamovie using the Phillips #2 screwdriver.
Once all of the screws are removed, pop the cassette cover off of the camera.
거의 끝나갑니다!
결론
