주요 콘텐츠로 건너뛰기
Sony Betamovie BMC-220 Power Button Replacement
필요한 것
  1. Sony Betamovie BMC-220 Power Button Replacement, Battery: 1 단계, 이미지 1/3 Sony Betamovie BMC-220 Power Button Replacement, Battery: 1 단계, 이미지 2/3 Sony Betamovie BMC-220 Power Button Replacement, Battery: 1 단계, 이미지 3/3
    • Orient your Betamovie so that the back of the device is sitting flat, and the bottom of the device is facing you.
    • Slide the RELEASE switch up to bring the hand drip down.
  2. Sony Betamovie BMC-220 Power Button Replacement: 2 단계, 이미지 1/3 Sony Betamovie BMC-220 Power Button Replacement: 2 단계, 이미지 2/3 Sony Betamovie BMC-220 Power Button Replacement: 2 단계, 이미지 3/3
    • Turn the BATTERY knob to OPEN, and open the lid.
    • Reminder: When inserting a new battery, make sure the knob is turned to OPEN.
    • Be careful not to point the hand grip down when turning the BATTERY knob. The battery pack may fall out.
  3. Sony Betamovie BMC-220 Power Button Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the Betamovie.
  4. Sony Betamovie BMC-220 Power Button Replacement, Power Button: 4 단계, 이미지 1/3 Sony Betamovie BMC-220 Power Button Replacement, Power Button: 4 단계, 이미지 2/3 Sony Betamovie BMC-220 Power Button Replacement, Power Button: 4 단계, 이미지 3/3
    • Remove the two screws (2mm x 6mm) on either side of the FILTER switch on the black and white side of the Betamovie using the Phillips #0 screwdriver.
    • Remove the two screws on the bottom of the camera on the side with the black and white face using the same screwdriver.
    • Remove the screws on the bottom of the back of the camera with the same screwdriver.
  5. Sony Betamovie BMC-220 Power Button Replacement: 5 단계, 이미지 1/2 Sony Betamovie BMC-220 Power Button Replacement: 5 단계, 이미지 2/2
    • Remove the silver rectangular piece at the top of the Betamovie using your hands.
    • Remove the two screws (2mm x 6mm) under the flat silver piece using the Phillips #1 screwdriver. The silver metal clip comes off once the crews are removed.
  6. Sony Betamovie BMC-220 Power Button Replacement: 6 단계, 이미지 1/3 Sony Betamovie BMC-220 Power Button Replacement: 6 단계, 이미지 2/3 Sony Betamovie BMC-220 Power Button Replacement: 6 단계, 이미지 3/3
    • Remove the black and white cover from the Betamovie.
    • Remove the power button from the black and white face.
결론
Jordan Bates
회원 가입일: 09/10/18
315 평판
안내서 3개 작성하였습니다
University of Alabama, Team S2-G5, Bedsole Fall 2018 University of Alabama, Team S2-G5, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S2G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 522
