주요 콘텐츠로 건너뛰기
Sony Bloggie 3D Player Battery Replacement
필요한 것
  1. Sony Bloggie 3D Player Battery Replacement, Front Cover: 1 단계, 이미지 1/1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Battery Replacement: 2 단계, 이미지 1/2 Sony Bloggie 3D Player Battery Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Battery Replacement, Back Cover: 3 단계, 이미지 1/2 Sony Bloggie 3D Player Battery Replacement, Back Cover: 3 단계, 이미지 2/2
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player Battery Replacement: 4 단계, 이미지 1/2 Sony Bloggie 3D Player Battery Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player Battery Replacement, Battery: 5 단계, 이미지 1/2 Sony Bloggie 3D Player Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Remove the battery with your fingers.
결론
Timothy Tran
회원 가입일: 01/30/13
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-12, Maness Winter 2013 Cal Poly, Team 7-12, Maness Winter 2013 회원
CPSU-MANESS-W13S7G12
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
You forgot to mention the need to flip the screen up (a screw holds it down) in order to get to a screw holding the back cover. Other than that, thank you for the info.
Rich Brewer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 29
전체 시간: 2,114
