소개
We turn our devices on and off every single day, and as such, the buttons wear over time. This repair guide will focus on replacing the electrical components controlling the On/Off buttons.
  1. Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board. Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  5. Use a plastic opening tool to loosen the back cover off the device. Once the back cover is loose, remove it gently by hand.
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  6. Using a spudger, carefully remove the metal casing that is attached to the ZIF connector.
    • Using a spudger, carefully remove the metal casing that is attached to the ZIF connector.
  7. Unclip the two plastic buttons with the spudger tool.
    • Unclip the two plastic buttons with the spudger tool.
    • The buttons each have a spring under them that will fall off, be careful not to lose them.
결론
Fred Saucedo
회원 가입일: 2013년 01월 11일
3 평판
안내서 1개 작성함
Cal Poly, Team 7-12, Maness Winter 2013 Cal Poly, Team 7-12, Maness Winter 2013 회원
CPSU-MANESS-W13S7G12
5 회원들
안내서 6개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 216
