소개
If the lens of the video camera cracks or becomes cloudy, replacing it can be costly and confusing. This guide shows how you can access the lens assembly on your own to make a quick replacement. To get to the lens assembly, you will need to have already removed the battery and the outer casing.
Open the cassette cover.
Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
Remove three screws from the circuit board on the left side of the video camera 3x3.6mm.
다른 2명이 해당 안내서를 완성하였습니다.
