주요 콘텐츠로 건너뛰기
Sony CDX-GT540UI CD Drive Replacement
필요한 것
  1. Sony CDX-GT540UI CD Drive Replacement, Front Panel: 1 단계, 이미지 1/1
    • Locate face-plate eject button.
  2. Sony CDX-GT540UI CD Drive Replacement: 2 단계, 이미지 1/2 Sony CDX-GT540UI CD Drive Replacement: 2 단계, 이미지 2/2
    • Press the eject button.
    • Remove the face-plate.
  3. Sony CDX-GT540UI CD Drive Replacement: 3 단계, 이미지 1/3 Sony CDX-GT540UI CD Drive Replacement: 3 단계, 이미지 2/3 Sony CDX-GT540UI CD Drive Replacement: 3 단계, 이미지 3/3
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
  4. Sony CDX-GT540UI CD Drive Replacement: 4 단계, 이미지 1/2 Sony CDX-GT540UI CD Drive Replacement: 4 단계, 이미지 2/2
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
  5. Sony CDX-GT540UI CD Drive Replacement: 5 단계, 이미지 1/1
    • Remove front panel.
  6. Sony CDX-GT540UI CD Drive Replacement, Back Panel: 6 단계, 이미지 1/1
    • Locate back panel.
  7. Sony CDX-GT540UI CD Drive Replacement: 7 단계, 이미지 1/3 Sony CDX-GT540UI CD Drive Replacement: 7 단계, 이미지 2/3 Sony CDX-GT540UI CD Drive Replacement: 7 단계, 이미지 3/3
    • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
  8. Sony CDX-GT540UI CD Drive Replacement: 8 단계, 이미지 1/1
    • Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove two 7.5mm Phillips #00 (black) screws from back panel.
  9. Sony CDX-GT540UI CD Drive Replacement: 9 단계, 이미지 1/1
    • Remove back panel.
    • On the back panel there will be thermal (white) paste. Do not touch.
  10. Sony CDX-GT540UI CD Drive Replacement, CD Drive: 10 단계, 이미지 1/1
    • Remove one 9.5mm Phillips #00 screw.
    • Rotate device 180 degrees and repeat step.
  11. Sony CDX-GT540UI CD Drive Replacement: 11 단계, 이미지 1/2 Sony CDX-GT540UI CD Drive Replacement: 11 단계, 이미지 2/2
    • Using plastic opening tool, detach the tabs. There are two on either side.
    • You will need to apply a decent amount of force to detach.
  12. Sony CDX-GT540UI CD Drive Replacement: 12 단계, 이미지 1/2 Sony CDX-GT540UI CD Drive Replacement: 12 단계, 이미지 2/2
    • Remove top panel.
  13. Sony CDX-GT540UI CD Drive Replacement: 13 단계, 이미지 1/1
    • Pull up CD drive slightly.
  14. Sony CDX-GT540UI CD Drive Replacement: 14 단계, 이미지 1/1
    • Disconnect motherboard connection.
  15. Sony CDX-GT540UI CD Drive Replacement: 15 단계, 이미지 1/1
    • Remove CD drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Odelkys Marquez
회원 가입일: 09/22/14
1,091 평판
안내서 7개 작성하였습니다
USF Tampa, Team 10-2, Brown Fall 2014 USF Tampa, Team 10-2, Brown Fall 2014 회원
USFT-BROWN-F14S10G2
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
This guide is listed as "difficult" yet only requires the use of a screwdriver and some prying tools. It would seem more appropriate to list it as "moderate" at most. I believe the motherboard guide has the same issue.
Also, you say PH#00 in the description of steps, but in the "tools" listing at the beginning of the guide, you said that a PH#0 was needed. These are not the same.
Dale Pearson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 702
