주요 콘텐츠로 건너뛰기
Sony CDX-GT540UI Fuse Replacement
  1. Sony CDX-GT540UI Fuse Replacement, Wiring Harness: 1 단계, 이미지 1/1
    • Locate the clip on the wiring harness.
  2. Sony CDX-GT540UI Fuse Replacement: 2 단계, 이미지 1/2 Sony CDX-GT540UI Fuse Replacement: 2 단계, 이미지 2/2
    • Press down on the clip like you would an Ethernet cable.
    • Rock harness side to side, pulling gently towards you until harness detaches.
  3. Sony CDX-GT540UI Fuse Replacement, Fuse: 3 단계, 이미지 1/1
    • Once you have removed the wiring harness.
    • Locate the fuse.
  4. Sony CDX-GT540UI Fuse Replacement: 4 단계, 이미지 1/1
    • Using your index finger and thumb on either side of the fuse.
  5. Sony CDX-GT540UI Fuse Replacement: 5 단계, 이미지 1/1
    • Rock back and forth gently pulling towards yourself until the fuse is removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Odelkys Marquez
회원 가입일: 09/22/14
1,091 평판
안내서 7개 작성하였습니다
USF Tampa, Team 10-2, Brown Fall 2014 USF Tampa, Team 10-2, Brown Fall 2014 회원
USFT-BROWN-F14S10G2
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
I would like to sincerely thank the person or persons that took the time ,energy and effort to put forth this information in an easily accessible way. BASICALLY YOU ARE COOL !!
germanspeedster - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 47
전체 시간: 9,260
