주요 콘텐츠로 건너뛰기
Sony CFS-204 Radio Cassette-Corder Batteries Replacement
필요한 것
  1. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: 1 단계, 이미지 1/1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: 2 단계, 이미지 1/3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: 2 단계, 이미지 2/3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: 2 단계, 이미지 3/3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
결론
Daniel
회원 가입일: 09/17/14
236 평판
안내서 1개 작성함
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 52
전체 시간: 1,462
