주요 콘텐츠로 건너뛰기
Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement
필요한 것
  1. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: 1 단계, 이미지 1/1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: 2 단계, 이미지 1/3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: 2 단계, 이미지 2/3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: 2 단계, 이미지 3/3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
  3. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Screws: 3 단계, 이미지 1/3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Screws: 3 단계, 이미지 2/3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Screws: 3 단계, 이미지 3/3
    • Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
  4. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Opening: 4 단계, 이미지 1/1
    • Press the EJECT button to open the cassette deck.
    • Pressing this button is required to allow the front face to separate from the case.
  5. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: 5 단계, 이미지 1/2 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: 5 단계, 이미지 2/2
    • Grasp the radio from the front and back halves and gently pull apart to separate them.
  6. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: 6 단계, 이미지 1/2 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: 6 단계, 이미지 2/2
    • Pull the white plug out from the red outlet in the Orange circuit board in the back face of the casing.
    • Take care not to break the red outlet off the circuit board.
    • The front and back portions of the casing are now separated from each other.
  7. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Volume or Tone Knob: 7 단계, 이미지 1/2 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Volume or Tone Knob: 7 단계, 이미지 2/2
    • Push upwards against bottom edge of the knob connection with a flat head screwdriver until the knob pops off.
    • You may wish to hold on to the knob so you don't lose it!
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brittany Patterson
회원 가입일: 09/17/14
693 평판
안내서 4개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 35
전체 시간: 2,781
