주요 콘텐츠로 건너뛰기
Sony CPF-IP001 Buttons on Main Speaker Replacement
필요한 것
  1. Sony CPF-IP001 Buttons on Main Speaker Replacement, Main Speaker Housing Disassembly: 1 단계, 이미지 1개 중 1개
    • Remove two 6mm Phillips #0 screws.
    • Remove two 7.5 mm Phillips #0 screws.
    • Remove seven 4 mm Phillips #0 screws.
  2. Sony CPF-IP001 Buttons on Main Speaker Replacement: 2 단계, 이미지 3개 중 1개 Sony CPF-IP001 Buttons on Main Speaker Replacement: 2 단계, 이미지 3개 중 2개 Sony CPF-IP001 Buttons on Main Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Remove six 4 mm Phillips #0 screws from the metal backing.
    • Remove six 5 mm Phillips #0 screws from the metal backing.
    • Using the plastic opening tool, remove the metal plate from the main speaker by gently pulling on it.
  3. Sony CPF-IP001 Buttons on Main Speaker Replacement: 3 단계, 이미지 2개 중 1개 Sony CPF-IP001 Buttons on Main Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the plastic dock cover by using two fingers to push the attached metal piece forward and slide it out of the holes.
  4. Sony CPF-IP001 Buttons on Main Speaker Replacement: 4 단계, 이미지 3개 중 1개 Sony CPF-IP001 Buttons on Main Speaker Replacement: 4 단계, 이미지 3개 중 2개 Sony CPF-IP001 Buttons on Main Speaker Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using the plastic opening tool, detach the wires connected to the metal plate
    • When disconnecting the wires, be careful not to pull on the wires themselves. Use the plastic opening tool and the connector to disconnect it.
    • Use the plastic opening tool to remove wires connected to the circuit board on the far right.
    • Use the tweezers to remove wires connected to the circuit board in between the two black wires.
    • Use the tweezers to press the release tab on the front and back of the plastic white wire head.
    • Once the tab is pressed on both sides, lift up to slide wire head out of socket.
  5. Sony CPF-IP001 Buttons on Main Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Remove two 5 mm Phillips #0 screws.
  6. Sony CPF-IP001 Buttons on Main Speaker Replacement: 6 단계, 이미지 3개 중 1개 Sony CPF-IP001 Buttons on Main Speaker Replacement: 6 단계, 이미지 3개 중 2개 Sony CPF-IP001 Buttons on Main Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Using the metal spudger, loosen the metal cap at the end of the speaker.
    • Slide down the loosened cap to remove it from the end of the speaker.
    • Simultaneously push down on the buttons and slide the speaker out from the casing.
  7. Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: 7 단계, 이미지 3개 중 1개 Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: 7 단계, 이미지 3개 중 2개 Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: 7 단계, 이미지 3개 중 3개
    • Remove two 6 mm Phillips #0 screws.
    • Gently lift the silver buttons up to remove.
  8. Sony CPF-IP001 Buttons on Main Speaker Replacement: 8 단계, 이미지 3개 중 1개 Sony CPF-IP001 Buttons on Main Speaker Replacement: 8 단계, 이미지 3개 중 2개 Sony CPF-IP001 Buttons on Main Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, disconnect the white connector from the circuit board.
    • Replace the broken circuit board with a new one.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Cole Stanley
회원 가입일: 04/14/15
290 평판
안내서 1개를 작성함
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015 회원
CPSU-MANESS-S15S6G14
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 15
전체 시간: 434
