주요 콘텐츠로 건너뛰기
Sony CPF-IP001 Power Plug Replacement
필요한 것
  1. Sony CPF-IP001 Power Plug Replacement, Power Plug: 1 단계, 이미지 3개 중 1개 Sony CPF-IP001 Power Plug Replacement, Power Plug: 1 단계, 이미지 3개 중 2개 Sony CPF-IP001 Power Plug Replacement, Power Plug: 1 단계, 이미지 3개 중 3개
    • The Sony Cradle Audio System will have 14 XXXX type of screws located on the bottom of the device.
    • Using a Phillips #2 screwdriver, remove all 14 screws.
  2. Sony CPF-IP001 Power Plug Replacement: 2 단계, 이미지 3개 중 1개 Sony CPF-IP001 Power Plug Replacement: 2 단계, 이미지 3개 중 2개 Sony CPF-IP001 Power Plug Replacement: 2 단계, 이미지 3개 중 3개
    • Once all of the screws are removed, the cover can be taken off using a metal spudger.
    • There are 8 more XXXX screws holding the circuit board in place that will need to be removed.
    • Once the screws are removed, a plastic spudger can be used to carefully move the circuit board away from the device.
    • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
  3. Sony CPF-IP001 Power Plug Replacement: 3 단계, 이미지 2개 중 1개 Sony CPF-IP001 Power Plug Replacement: 3 단계, 이미지 2개 중 2개
    • The first of the 3 wires can easily be found and is connected to the board via a clip.
    • To remove the clip squeeze the tap and pull it out.
    • There are still 2 more wires connected to the board. Now that the first has been removed the other two can be more easily reached.
  4. Sony CPF-IP001 Power Plug Replacement: 4 단계, 이미지 3개 중 1개 Sony CPF-IP001 Power Plug Replacement: 4 단계, 이미지 3개 중 2개 Sony CPF-IP001 Power Plug Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The wire furthest to the left of the device can be removed in the same way that he first was removed. Simply squeeze the clip and pull out.
    • The final wire (furthest to the right) can be carefully removed using a pair of tweezers.
    • Now the circuit board has been completely removed from the device and can be set aside.
  5. Sony CPF-IP001 Power Plug Replacement: 5 단계, 이미지 2개 중 1개 Sony CPF-IP001 Power Plug Replacement: 5 단계, 이미지 2개 중 2개
    • Next the housing for the power switch and power cord must be removed.
    • Remove the 4 XXXX screws using a Phillips #2 screwdriver.
  6. Sony CPF-IP001 Power Plug Replacement: 6 단계, 이미지 3개 중 1개 Sony CPF-IP001 Power Plug Replacement: 6 단계, 이미지 3개 중 2개 Sony CPF-IP001 Power Plug Replacement: 6 단계, 이미지 3개 중 3개
    • Remove these next 6 XXXX screws using a Phillips #2 screwdriver.
    • The housing is now disconnected from the device and can be pulled out from the side.
    • The power housing will come out as a whole unit with the subwoofer air tunnel.
  7. Sony CPF-IP001 Power Plug Replacement: 7 단계, 이미지 1개 중 1개
    • The subwoofer air tunnel can be removed by unscrewing the 2 XXXX screws with a Phillips #2 screwdriver.
결론
작성자
3다른 기여자 명과 함께
Mike Bolton
회원 가입일: 04/14/15
473 평판
안내서 4개를 작성함
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015 회원
CPSU-MANESS-S15S6G14
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 9
전체 시간: 273
