소개
If the audio in your device is not working, you may need to replace the audio module. This easy step-by-step guide will walk you through the necessary steps to do so.
필요한 것
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
Unscrew the 2.5mm screw on the top portion of the audio module with a Phillips #00 screwdriver.
거의 끝나갑니다!
결론
