주요 콘텐츠로 건너뛰기
Sony Clie PEG-NR70 Battery Pack Replacement
필요한 것
  1. Sony Clie PEG-NR70 Battery Pack Replacement, The Case: 1 단계, 이미지 1/1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Battery Pack Replacement: 2 단계, 이미지 1/1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Battery Pack Replacement: 3 단계, 이미지 1/2 Sony Clie PEG-NR70 Battery Pack Replacement: 3 단계, 이미지 2/2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: 4 단계, 이미지 1/2 Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: 4 단계, 이미지 2/2
    • Pull up on the black tab on the battery pack to reveal the power cord.
  5. Sony Clie PEG-NR70 Battery Pack Replacement: 5 단계, 이미지 1/1
    • Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
    • Be careful to not tear the cables! They are very thin.
  6. Sony Clie PEG-NR70 Battery Pack Replacement: 6 단계, 이미지 1/1
    • Gently peel back the adhesive to completely disconnect the battery pack from device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Courtney
회원 가입일: 04/19/13
49 평판
안내서 2개 작성하였습니다
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013 회원
CPSU-MANESS-S13S14G11
5 회원들
안내서 8개 작성하였습니다
댓글 한 개
Hi, this is really helpful, thank you.
Richard Hancock - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 14
전체 시간: 2,154
