소개
If your device is not holding a charge or simply will not turn on, it is possible that you need to replace the battery. This easy guide will take you through the necessary steps in order to remove the battery so you may install a new one.
필요한 것
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
