소개
If the screen is damaged, then you may need to replace it. This guide will walk you through the process of replacing your screen with a new one.
필요한 것
Remove the two 1.5mm screws (one on the right and one on the left side) on the screen portion of the device with a Phillips #00 screwdriver.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
