주요 콘텐츠로 건너뛰기
Sony Clie PEG-NR70 Speaker Rail Replacement
필요한 것
  1. Sony Clie PEG-NR70 Speaker Rail Replacement, The Case: 1 단계, 이미지 1/1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Speaker Rail Replacement: 2 단계, 이미지 1/1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Speaker Rail Replacement: 3 단계, 이미지 1/2 Sony Clie PEG-NR70 Speaker Rail Replacement: 3 단계, 이미지 2/2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Speaker Rail Replacement, Speaker Rail: 4 단계, 이미지 1/2 Sony Clie PEG-NR70 Speaker Rail Replacement, Speaker Rail: 4 단계, 이미지 2/2
    • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
    • Be careful not to tear the speaker wires! They are very thin.
    • Remove the tape holding speaker wire by peeling it away.
  5. Sony Clie PEG-NR70 Speaker Rail Replacement: 5 단계, 이미지 1/1
    • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Remove the speaker rail vertically from the device.
결론
Daniel Soski
회원 가입일: 04/18/13
57 평판
안내서 6개 작성하였습니다
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013 회원
CPSU-MANESS-S13S14G11
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 302
