1. Remove the six screws holding the outside case of the Sony Clie.
    • Remove the six screws holding the outside case of the Sony Clie.
  2. Remove the six screws holding the outer case.
    • Remove the six screws holding the outer case.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove the two screws holding the battery harness in place.
    • Remove the two screws holding the battery harness in place.
  5. Gently pull the power cable from the socket.
    • Gently pull the power cable from the socket.
  6. The battery harness is now removed. Install the new harness in reverse order.
    • The battery harness is now removed. Install the new harness in reverse order.
결론
Emily
회원 가입일: 2011년 10월 18일
1 평판
안내서 3개 작성하였습니다
James Madison, Team 1-4, Allen Fall 2011 James Madison, Team 1-4, Allen Fall 2011 회원
JMU-ALLEN-F11S1G4
3 회원들
안내서 4개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,084
