주요 콘텐츠로 건너뛰기
Sony Clie PEG-SL10 Motherboard Replacement
필요한 것
  1. Sony Clie PEG-SL10 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the six screws holding the case together.
  2. Sony Clie PEG-SL10 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the seven screws holding the motherboard to the device.
  3. Sony Clie PEG-SL10 Motherboard Replacement: 3 단계, 이미지 1/1
    • Unclip the battery harness power cable from the motherboard.
  4. Sony Clie PEG-SL10 Motherboard Replacement: 4 단계, 이미지 1/1
    • Unclip the scroll wheel power cable from the motherboard.
  5. Sony Clie PEG-SL10 Motherboard Replacement: 5 단계, 이미지 1/1
    • Pull the left clip to remove the cable.
  6. Sony Clie PEG-SL10 Motherboard Replacement: 6 단계, 이미지 1/1
    • Pull out the two clips from the center to remove the power cable.
  7. Sony Clie PEG-SL10 Motherboard Replacement: 7 단계, 이미지 1/1
    • Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
  8. Sony Clie PEG-SL10 Motherboard Replacement: 8 단계, 이미지 1/1
    • Extend both sides of the left clip to remove the power cable.
  9. Sony Clie PEG-SL10 Motherboard Replacement: 9 단계, 이미지 1/1
    • Pull out the center clip to remove the power cable.
  10. Sony Clie PEG-SL10 Motherboard Replacement: 10 단계, 이미지 1/1
    • Pull the right clip out to remove the right cable.
  11. Sony Clie PEG-SL10 Motherboard Replacement: 11 단계, 이미지 1/1
    • The motherboard is removed. To install the new motherboard, follow the directions in reverse.
결론
Emily
회원 가입일: 10/18/11
3 평판
안내서 3개 작성하였습니다
James Madison, Team 1-4, Allen Fall 2011 James Madison, Team 1-4, Allen Fall 2011 회원
JMU-ALLEN-F11S1G4
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
I have a full reset whenever I take the battery out to recharge it. Given that all replacement motherboards will be as old as the unit, is there anyway to fix the board (I presume it’s a capacitor or super cell that keeps the charge long enough to swap the battery over normally?). The three cells seem to be soldered onto the board, but I presume could be replaced?
Anyone know of a way to fix this?
Benjamin S. Leveritt - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 1,346
