주요 콘텐츠로 건너뛰기
Sony Clie PEG-UX50 Tilt Screen Replacement
필요한 것
  1. Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: 1 단계, 이미지 1/3 Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: 1 단계, 이미지 2/3 Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: 1 단계, 이미지 3/3
    • Take off the screws located on the two sides of the tilt screen.
    • Unscrew the screw located at the tilt base of the screen.
  2. Sony Clie PEG-UX50 Tilt Screen Replacement: 2 단계, 이미지 1/3 Sony Clie PEG-UX50 Tilt Screen Replacement: 2 단계, 이미지 2/3 Sony Clie PEG-UX50 Tilt Screen Replacement: 2 단계, 이미지 3/3
    • Gently remove the back plate of the tilt screen by sliding it upward.
    • With caution, lift the wires from the track in the back plate.
  3. Sony Clie PEG-UX50 Tilt Screen Replacement: 3 단계, 이미지 1/2 Sony Clie PEG-UX50 Tilt Screen Replacement: 3 단계, 이미지 2/2
    • Disconnect the thin USB cable attached to the Integrated Circuit.
  4. Sony Clie PEG-UX50 Tilt Screen Replacement: 4 단계, 이미지 1/2 Sony Clie PEG-UX50 Tilt Screen Replacement: 4 단계, 이미지 2/2
    • Detach the plastic black frame from in between the plate and the LCD.
    • Do not disconnect the display from the board yet.
  5. Sony Clie PEG-UX50 Tilt Screen Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect the thin connector from the face plate using tweezers.
  6. Sony Clie PEG-UX50 Tilt Screen Replacement: 6 단계, 이미지 1/1
    • Quickly release and disconnect the thick cable with your hands.
결론
Follow these instructions in reverse order to reassemble your device.
Rishad R Rai
회원 가입일: 04/28/11
1 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-4, Nelson Spring 2011 CSU Los Angeles, Team 1-4, Nelson Spring 2011 회원
CSULA-NELSON-S11S1G4
5 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 2,770
