주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-H1 Back Panel Replacement
필요한 것
  1. Sony Cyber-Shot DSC-H1 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 Back Panel Replacement: 2 단계, 이미지 1/3 Sony Cyber-Shot DSC-H1 Back Panel Replacement: 2 단계, 이미지 2/3 Sony Cyber-Shot DSC-H1 Back Panel Replacement: 2 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 Back Panel Replacement: 3 단계, 이미지 1/2 Sony Cyber-Shot DSC-H1 Back Panel Replacement: 3 단계, 이미지 2/2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
결론
Trystan Jasperson
회원 가입일: 03/17/18
231 평판
안내서 2개 작성하였습니다
Baylor, Team S5-G4, Williams Spring 2018 Baylor, Team S5-G4, Williams Spring 2018 회원
BU-WILLIAMS-S18S5G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 12
전체 시간: 510
