주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-H1 Lens Replacement
필요한 것
  1. Sony Cyber-Shot DSC-H1 Lens Replacement, Back Panel: 1 단계, 이미지 1/1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 Lens Replacement: 2 단계, 이미지 1/3 Sony Cyber-Shot DSC-H1 Lens Replacement: 2 단계, 이미지 2/3 Sony Cyber-Shot DSC-H1 Lens Replacement: 2 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 Lens Replacement: 3 단계, 이미지 1/2 Sony Cyber-Shot DSC-H1 Lens Replacement: 3 단계, 이미지 2/2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 Lens Replacement, LCD Screen: 4 단계, 이미지 1/1
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 Lens Replacement: 5 단계, 이미지 1/1
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
  6. Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: 6 단계, 이미지 1/2 Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: 6 단계, 이미지 2/2
    • Unscrew and remove the gray backing behind the LCD screen.
  7. Sony Cyber-Shot DSC-H1 Lens Replacement: 7 단계, 이미지 1/3 Sony Cyber-Shot DSC-H1 Lens Replacement: 7 단계, 이미지 2/3 Sony Cyber-Shot DSC-H1 Lens Replacement: 7 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
    • Disconnect the white conductive tape.
    • Remove the blue panel.
    • Use tweezers to remove the three conductive tape strips on the right side.
  8. Sony Cyber-Shot DSC-H1 Lens Replacement: 8 단계, 이미지 1/2 Sony Cyber-Shot DSC-H1 Lens Replacement: 8 단계, 이미지 2/2
    • Use tweezers to remove the orange conductive tape located below the shutter.
    • Unplug the three ZIF connectors from the motherboard.
  9. Sony Cyber-Shot DSC-H1 Lens Replacement: 9 단계, 이미지 1/1
    • Flip up the blue overlapping board at the top.
    • Use tweezers to disconnect the remaining connectors.
  10. Sony Cyber-Shot DSC-H1 Lens Replacement: 10 단계, 이미지 1/1
    • Remove the motherboard and battery pack unit.
  11. Sony Cyber-Shot DSC-H1 Lens Replacement: 11 단계, 이미지 1/3 Sony Cyber-Shot DSC-H1 Lens Replacement: 11 단계, 이미지 2/3 Sony Cyber-Shot DSC-H1 Lens Replacement: 11 단계, 이미지 3/3
    • Use a screwdriver to remove 5 screws on plastic panel.
    • Remove the single screw on the silver panel in the center.
  12. Sony Cyber-Shot DSC-H1 Lens Replacement: 12 단계, 이미지 1/3 Sony Cyber-Shot DSC-H1 Lens Replacement: 12 단계, 이미지 2/3 Sony Cyber-Shot DSC-H1 Lens Replacement: 12 단계, 이미지 3/3
    • Use tweezers to remove the blue control panel.
    • Remove the lens from the camera.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Charlie Pugeda
회원 가입일: 03/19/18
505 평판
안내서 3개 작성하였습니다
Baylor, Team S5-G4, Williams Spring 2018 Baylor, Team S5-G4, Williams Spring 2018 회원
BU-WILLIAMS-S18S5G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 26
전체 시간: 1,584
