주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-S90 Back Case Replacement
필요한 것
  1. Sony Cyber-Shot DSC-S90 Back Case Replacement, Batteries: 1 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Back Case Replacement, Batteries: 1 단계, 이미지 2/2
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 Back Case Replacement: 2 단계, 이미지 1/1
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 Back Case Replacement, Back Case: 3 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Back Case Replacement, Back Case: 3 단계, 이미지 2/2
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 Back Case Replacement: 4 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Back Case Replacement: 4 단계, 이미지 2/2
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 Back Case Replacement: 5 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Back Case Replacement: 5 단계, 이미지 2/2
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 Back Case Replacement: 6 단계, 이미지 1/1
    • Pull apart the back case from the main body of the camera.
결론
Alecsander da Silva
회원 가입일: 10/30/19
293 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S4-G5, Saloman Fall 2019 UMass Dartmouth, Team S4-G5, Saloman Fall 2019 회원
UMASSD-SALOMAN-F19S4G5
3 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 210
