주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement
필요한 것
  1. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: 1 단계, 이미지 1/2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: 1 단계, 이미지 2/2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 2 단계, 이미지 1/2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 2 단계, 이미지 2/2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 3 단계, 이미지 1/2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 3 단계, 이미지 2/2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery/Memory Card Door Seal: 5 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the two 2mm screws on the battery/memory card cover seal.
  6. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: 6 단계, 이미지 1/1
    • Using your fingers, remove the battery/memory card door seal.
결론
Kellen Fulkerson
회원 가입일: 04/11/17
689 평판
안내서 6개 작성하였습니다
댓글 3개
hi sir do you have battery lock for replacement ?
John Anthony Geronez - 답글
the Cyber shot by Sony has a lousy battery door it breaks very easily it's made of cheap plastic do you have any replacements for it?
SHELIAH HIPPS - 답글
Where can I get the door catch - is it still available?
sid123 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 19
전체 시간: 1,641
