주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-TX30 Outer Shell Replacement
필요한 것
  1. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 2 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 2 단계, 이미지 2개 중 2개
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 3 단계, 이미지 2개 중 2개
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement, Outer Shell: 5 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 6 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 7 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 8 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 9 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 10 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 11 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 12 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 12 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 13 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX30 Outer Shell Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the front casing of the device.
결론
작성자
3다른 기여자 명과 함께
Kellen Fulkerson
회원 가입일: 04/11/17
689 평판
안내서 6개를 작성함
1가이드 댓글
hello sir do you have sony tx30 case ? because my battery lock hole loose … please thanks
John Anthony Geronez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 1,169
