주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-TX9 Card Reader Replacement
필요한 것
  1. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: 1 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: 1 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
  2. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 2 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 2 단계, 이미지 2개 중 2개
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
  3. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
  4. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 4 단계, 이미지 2개 중 2개
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (케이블 커넥터 인식 및 분리) page for assistance.
  5. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: 5 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: 5 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: 5 단계, 이미지 3개 중 3개
    • Using a Phillips head screw driver, remove the two screws for the metal plate on the bottom.
    • Detach the smaller ribbon cables by sliding them out.
    • Detach the large ribbon cable by flipping the small black holder in an upright position and then sliding the cable out carefully.
    • Detach the ribbon cables slowly and carefully or they will rip.
  6. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 6 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully remove the Memory card circuit board.
    • The circuit board should come out with little force. If it does not, make sure all connections are disconnected.
결론
작성자
2다른 기여자 명과 함께
Yegor Shea
회원 가입일: 03/26/17
301 평판
안내서 3개를 작성함
UMass Dartmouth, Team S4-G3, Julie Spring 2017 UMass Dartmouth, Team S4-G3, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G3
5 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 431
