주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-W120 Back Case Replacement
필요한 것
  1. Sony Cyber-Shot DSC-W120 Back Case Replacement, Front Case: 1 단계, 이미지 1/1
    • Unscrew the screws on the right side of the camera.
  2. Sony Cyber-Shot DSC-W120 Back Case Replacement: 2 단계, 이미지 1/2 Sony Cyber-Shot DSC-W120 Back Case Replacement: 2 단계, 이미지 2/2
    • Using a plastic opening tool, lift and remove the silver piece on the right side of the camera.
  3. Sony Cyber-Shot DSC-W120 Back Case Replacement: 3 단계, 이미지 1/3 Sony Cyber-Shot DSC-W120 Back Case Replacement: 3 단계, 이미지 2/3 Sony Cyber-Shot DSC-W120 Back Case Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to push the tabs on each side of the front case forward.
    • Remove the front case.
  4. Sony Cyber-Shot DSC-W120 Back Case Replacement, Back Case: 4 단계, 이미지 1/1
    • Lift and remove the silver piece on the left side of the camera with a plastic opening tool.
    • Unscrew the two screws on the left side of the camera.
  5. Sony Cyber-Shot DSC-W120 Back Case Replacement: 5 단계, 이미지 1/1
    • Unscrew the three screws at the bottom of the camera.
  6. Sony Cyber-Shot DSC-W120 Back Case Replacement: 6 단계, 이미지 1/2 Sony Cyber-Shot DSC-W120 Back Case Replacement: 6 단계, 이미지 2/2
    • Using a plastic opening tool, carefully separate and remove the back case.
결론
Dana Sanchez
회원 가입일: 10/21/14
51 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-5, Leahy Fall 2014 USF Tampa, Team 1-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 13
전체 시간: 386
