주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-W120 LCD Screen Replacement
필요한 것
  1. Sony Cyber-Shot DSC-W120 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Unscrew the screws on the right side of the camera.
  2. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 2 단계, 이미지 1/2 Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 2 단계, 이미지 2/2
    • With a plastic opening tool, gently lift and remove the silver piece on the right side of the camera.
  3. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 3 단계, 이미지 1/3 Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 3 단계, 이미지 2/3 Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to carefully lift and remove the front case.
  4. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Gently pry the silver piece on the left side of the camera off with a plastic opening tool.
  5. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Unscrew the three screws on the bottom of the camera.
  6. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 6 단계, 이미지 1/2 Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to lift and remove the back case.
  7. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 7 단계, 이미지 1/1
    • Remove the screw located above the mode dial.
  8. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 8 단계, 이미지 1/2 Sony Cyber-Shot DSC-W120 LCD Screen Replacement: 8 단계, 이미지 2/2
    • Lift the LCD display from the rest of the camera.
    • Use tweezers to carefully separate the connecting tape.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher
회원 가입일: 10/07/14
10 평판
안내서 1개 작성함
USF Tampa, Team 1-5, Leahy Fall 2014 USF Tampa, Team 1-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G5
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Hi, for step 8 the wider of the two ribbon cables is held by a black/dark grey clamp on the connector on the motherboard, it's best to release the clamp before pulling the cable out.
Do that by gently lifting it with a fingernail, it hinges on the screen side, it will rotate about 90 degrees to open. When reassembling it's simply the reverse, so push the cable in to the connector with the clamp open, when the cable is fully in there will be about 1mm of the gold connectors on the ribbon cable showing still, and then just clamp connector clamp shut but pushing it with your thumb.
Tony Neville - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 17
전체 시간: 942
