주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-W120 Lens Assembly Replacement
필요한 것
  1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 1/1
    • Unscrew the screws on the right side of the camera.
  2. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 2 단계, 이미지 1/2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 2 단계, 이미지 2/2
    • Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed.
  3. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 3 단계, 이미지 1/3 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 3 단계, 이미지 2/3 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to separate the front case of the camera, and gently remove it.
  4. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to remove the silver piece on the left side of the camera.
  5. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 5 단계, 이미지 1/1
    • Remove the three screws from the bottom of the camera.
  6. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 6 단계, 이미지 1/2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 6 단계, 이미지 2/2
    • Carefully remove the back case with a plastic opening tool.
  7. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 7 단계, 이미지 1/1
    • Unscrew the screw just above the mode dial.
  8. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Lift the display from the rest of the camera and gently separate the connecting tape using tweezers.
  9. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 9 단계, 이미지 1/2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 9 단계, 이미지 2/2
    • Separate the tape connecting the lens to the rest of the camera using tweezers.
    • Remove the lens.
  10. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 10 단계, 이미지 1/2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 10 단계, 이미지 2/2
    • Insert wisdom here.
  11. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: 11 단계, 이미지 1/1
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dana Sanchez
회원 가입일: 10/21/14
51 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-5, Leahy Fall 2014 USF Tampa, Team 1-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 56
전체 시간: 1,621
