주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-W170 Top Panel Replacement
필요한 것
  1. Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: 1 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: 1 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: 1 단계, 이미지 3개 중 3개
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: 4 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: 4 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: 4 단계, 이미지 3개 중 3개
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Gently open the front panel and remove it from the rest of the camera.
  6. Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD: 6 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD: 6 단계, 이미지 2개 중 2개
    • Remove the first side panel to the left of the LCD.
    • Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
  7. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 7 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 7 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 7 단계, 이미지 3개 중 3개
    • Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
  8. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 8 단계, 이미지 2개 중 2개
    • Gently push the connector through the hole to separate the LCD from the metal casing.
  9. Sony Cyber-Shot DSC-W170 Top Panel Replacement, Top Panel: 9 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Top Panel: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lift up the black bar on the top flat ribbon cable with tweezers.
    • Gently pull the flat ribbon cable until it disconnects from the lens assembly.
    • Be gentle when dealing with the flat ribbon cable.
  10. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 10 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 10 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the six 4 mm screws from the lens assembly with a Phillips #000 screwdriver.
  11. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the two flat ribbon cables with tweezers.
  12. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 12 단계, 이미지 1개 중 1개
    • Peel back the flash assembly on the back of the lens.
    • Remove the two 4 mm screws with a Phillips #000 screwdriver.
  13. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 13 단계, 이미지 1개 중 1개
    • Pull out the battery from the side and remove the white tape from the battery assembly with tweezers.
  14. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 14 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-W170 Top Panel Replacement: 14 단계, 이미지 2개 중 2개
    • Disconnect the flat ribbon cable that connects the motherboard to the lens assembly with tweezers.
  15. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 15 단계, 이미지 1개 중 1개
    • Push out the lens assembly very gently.
  16. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the 4 mm screw from the bottom side of the top panel with a Phillips #000 screwdriver.
  17. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the silver 4 mm screw with a Phillips #000 screwdriver from the silver bracket connected to the motherboard.
  18. Sony Cyber-Shot DSC-W170 Top Panel Replacement: 18 단계, 이미지 1개 중 1개
    • Pull the top panel off gently.
결론
작성자
4다른 기여자 명과 함께
Katharina Anglett
회원 가입일: 09/13/23
529 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 269
