주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-W830 Button Board Replacement
필요한 것
  1. Sony Cyber-Shot DSC-W830 Button Board Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Button Board Replacement: 2 단계, 이미지 1/1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Button Board Replacement: 3 단계, 이미지 1/1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: 4 단계, 이미지 1/3 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: 4 단계, 이미지 2/3 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: 4 단계, 이미지 3/3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Button Board Replacement: 5 단계, 이미지 1/3 Sony Cyber-Shot DSC-W830 Button Board Replacement: 5 단계, 이미지 2/3 Sony Cyber-Shot DSC-W830 Button Board Replacement: 5 단계, 이미지 3/3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Button Board Replacement: 6 단계, 이미지 1/3 Sony Cyber-Shot DSC-W830 Button Board Replacement: 6 단계, 이미지 2/3 Sony Cyber-Shot DSC-W830 Button Board Replacement: 6 단계, 이미지 3/3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: 7 단계, 이미지 1/2 Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: 7 단계, 이미지 2/2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 Button Board Replacement: 8 단계, 이미지 1/2 Sony Cyber-Shot DSC-W830 Button Board Replacement: 8 단계, 이미지 2/2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Addyson Salalila
회원 가입일: 09/15/16
301 평판
안내서 2개 작성하였습니다
USF Tampa, Team 17-1, Blackwell Fall 2016 USF Tampa, Team 17-1, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 25
전체 시간: 1,238
