소개
This will show you how to disassemble the camera and show you how to safely and successfully remove the LCD.
필요한 것
Remove the six 3.5mm Phillips #000 screws.
Rotate the lock away from the camera.
Pry the device open with the plastic opening tool.
There is also a small corner piece, coloured the same as camera body, at the battery compartment corner which will also fall out. be careful not to loose it - it’s a bit fidly to fit back when re-assembling, but logcal. The Ifixit tweezers where a great help in locating it back on its pins.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 5개
hii
plaz help me
pless need a sony dsc-'''''wx''''' 830 display LED
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Sony dsc s2000 model camera need
Display & lens unit
