주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement
필요한 것
  1. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: 1 단계, 이미지 1/3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: 1 단계, 이미지 2/3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: 1 단계, 이미지 3/3
    • Remove the battery before beginning.
    • Remove the three screws from the side of the lens using a JIS #000 screwdriver.
    • Remove the longer single screw from the bottom of the lens using a JIS #000 screwdriver.
  2. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 2 단계, 이미지 1/2 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 2 단계, 이미지 2/2
    • Remove the housing over the lens circuit board.
    • When removing the housing from over the circuit board, be cautious of static when touching the circuit board as to not fry any necessary components.
  3. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 3 단계, 이미지 1/1
    • Unplug the micro-USB type B port from the main circuit board in the lens.
    • When handling the flex cable, be careful as to not destroy this delicate part and cause damage to other components.
  4. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 4 단계, 이미지 2/2
    • Set the camera aside.
    • Remove the two JIS #000 screws connecting the micro-USB type B port to the housing frame.
  5. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 5 단계, 이미지 1/3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 5 단계, 이미지 2/3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: 5 단계, 이미지 3/3
    • Remove the damaged micro-USB type B port by lightly pulling near the cable connector.
    • Remove the micro-USB port from the case and replace it with a new micro-USB type B port.
결론
Juliana Sinobio
회원 가입일: 09/08/21
121 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 930
