주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-H20 Flash Assembly Replacement
필요한 것
  1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 1/2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 2/2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 2 단계, 이미지 1/1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 3 단계, 이미지 2/2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 4 단계, 이미지 1/3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 4 단계, 이미지 2/3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 4 단계, 이미지 3/3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 5 단계, 이미지 2/2
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 6 단계, 이미지 1/3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 6 단계, 이미지 2/3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 6 단계, 이미지 3/3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 7 단계, 이미지 1/1
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 8 단계, 이미지 1/2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: 8 단계, 이미지 2/2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Reuben Martinez
회원 가입일: 02/23/15
333 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-1, Leahy Winter 2015 USF Tampa, Team 1-1, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G1
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
how to bye power sutter unit
aloke mondal - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 1,424
