주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-H20 Front Cover Replacement
필요한 것
  1. Sony Cyber-shot DSC-H20 Front Cover Replacement, Front Cover: 1 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Front Cover Replacement, Front Cover: 1 단계, 이미지 2개 중 2개
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Front Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Front Cover Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Front Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Front Cover Replacement: 4 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H20 Front Cover Replacement: 4 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H20 Front Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Front Cover Replacement: 5 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Front Cover Replacement: 5 단계, 이미지 2개 중 2개
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Front Cover Replacement: 6 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H20 Front Cover Replacement: 6 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H20 Front Cover Replacement: 6 단계, 이미지 3개 중 3개
    • Pry the front cover of the camera off with the plastic opening tool.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Randal Ackett
회원 가입일: 02/23/15
182 평판
안내서 1개를 작성함
USF Tampa, Team 1-1, Leahy Winter 2015 USF Tampa, Team 1-1, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G1
3 회원들
안내서 10개를 작성함
댓글 한 개
I need a new battery port. It has a broken lid and doesn’t keep it closed. Anyone knows where can I get one?
rubens brakarz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 1,043
