주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-H20 Lens Assembly Replacement
필요한 것
  1. Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 2개 중 2개
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 4 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 4 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Place the camera upside down with the battery port positioned upward and the battery port open.
  6. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 6 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 6 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Lift up the gray plastic facing in order to uncover the motherboard and the ribbon cable ports.
  10. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 10 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully flip up the three black clasps holding the lens cables to the motherboard.
    • Slide the cables from the ports.
  11. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the lens and attached ribbon cables from the camera in order to switch this lens with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Rachel Payne
회원 가입일: 02/23/15
416 평판
안내서 2개를 작성함
USF Tampa, Team 1-1, Leahy Winter 2015 USF Tampa, Team 1-1, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G1
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 3,194
