주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-H20 Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-H20 Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Screen Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Screen Replacement: 4 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H20 Screen Replacement: 4 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H20 Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Screen Replacement: 6 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H20 Screen Replacement: 6 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H20 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the power shutter unit.
  8. Sony Cyber-shot DSC-H20 Screen Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two screws from the bottom of the motherboard.
  10. Sony Cyber-shot DSC-H20 Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to assist you in separating the metal frame from the back cover of the camera.
  11. Sony Cyber-shot DSC-H20 Screen Replacement: 11 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Flip the metal frame over to the left side of the camera and onto the surface on which you are working.
  12. Sony Cyber-shot DSC-H20 Screen Replacement: 12 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Now remove the LCD screen by bringing the back cover over to the left so that the LCD screen falls into your hand.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Rachel Payne
회원 가입일: 02/23/15
416 평판
안내서 2개를 작성함
USF Tampa, Team 1-1, Leahy Winter 2015 USF Tampa, Team 1-1, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G1
3 회원들
안내서 10개를 작성함
1가이드 댓글
Thank you so much. I could successfully open the camera and got the LCD display out. But I couldn't find out how to replace the LCD, I wanted to mean where to open the LCD cable?
ummejamil - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 48
전체 시간: 2,506
