주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-H200 LCD Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H200 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H200 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 LCD Screen Replacement: 9 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H200 LCD Screen Replacement: 9 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H200 LCD Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
결론
작성자
6다른 기여자 명과 함께
Elizabeth Morrison
회원 가입일: 04/08/15
287 평판
안내서 2개를 작성함
1가이드 댓글
Where can you purchase a new replacement monitor?
Butch Sullivan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 21
전체 시간: 2,922
