주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-H200 SD Door Replacement
필요한 것
  1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: 1 단계, 이미지 1/2 Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: 1 단계, 이미지 2/2
    • Using a screwdriver, remove four 6mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 SD Door Replacement: 2 단계, 이미지 1/1
    • Using a screwdriver, remove the two 6mm screws on the bottom.
    • Using a screwdriver, remove the four 3mm screws on the bottom.
  3. Sony Cyber-shot DSC-H200 SD Door Replacement: 3 단계, 이미지 1/1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 SD Door Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-H200 SD Door Replacement: 4 단계, 이미지 2/2
    • Using the blue plastic opening tools, remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 SD Door Replacement: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-H200 SD Door Replacement: 5 단계, 이미지 2/2
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable).
    • Using the blue plastic opening tool remove the LCD Screen from the motherboard.
  6. Sony Cyber-shot DSC-H200 SD Door Replacement: 6 단계, 이미지 1/1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 SD Door Replacement: 7 단계, 이미지 1/1
    • Lift the holding plate away from the motherboard and set aside (the pin attaching the door to the body is now accessible).
  8. Sony Cyber-shot DSC-H200 SD Door Replacement: 8 단계, 이미지 1/2 Sony Cyber-shot DSC-H200 SD Door Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers remove the pin that attaches the door to the body.
  9. Sony Cyber-shot DSC-H200 SD Door Replacement: 9 단계, 이미지 1/1
    • Remove the door.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elizabeth Morrison
회원 가입일: 04/08/15
287 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,589
