주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Sony Cyber-shot DSC-HX1 Battery Replacement
  1. Sony Cyber-shot DSC-HX1 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Battery Replacement: 2 단계, 이미지 1/1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Battery Replacement: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-HX1 Battery Replacement: 3 단계, 이미지 2/2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
결론
To reassemble your device, insert the new battery in the compartment, making sure that your battery has the correct orientation, then follow these instructions in reverse order.
Brianna Greenlaw
회원 가입일: 04/06/15
1,181 평판
안내서 5개 작성하였습니다
Cal Poly, Team 17-3, Forte Spring 2015 Cal Poly, Team 17-3, Forte Spring 2015 회원
CPSU-FORTE-S15S17G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 1,148
