주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-HX1 LCD Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-HX1 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
    • Extend the LCD screen away from the camera to access the screws on the back of its housing.
  2. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew the three #00 2.0 mm Phillips screws on the back of the casing.
  3. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Place the camera with the lens down.
    • Tilt the screen upwards to see the screw on the bottom of the housing.
    • Unscrew this #00 4.0 mm Phillips screw.
  4. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Pry the casing apart using your plastic opening tool. Begin by prying at the hole where you removed the screw and continue along the seam.
  5. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the transparent section of the plastic housing off.
    • Lift the rubber screen bumper off of the screen.
  6. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Pull up on the screen to reveal the data attachment cable.
    • Carefully pull the LCD screen away from enclosure to remove the cable and screen completely.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Brianna Greenlaw
회원 가입일: 04/06/15
1,289 평판
안내서 5개를 작성함
Cal Poly, Team 17-3, Forte Spring 2015 Cal Poly, Team 17-3, Forte Spring 2015 회원
CPSU-FORTE-S15S17G3
4 회원들
안내서 10개를 작성함
5가이드 댓글
What is the lcd screen part number? And where can i find it online? I need to replace my dads cracked screen.
sportyvangchick - 답글
lao90227ay
s300gc05lb9e21xmo usp5280371
lajos rohony - 답글
Screen LCDOnline booking
prince Choudhary - 답글
qual tela de lcd posso usar?
não achei
Thayane Laurencio - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 46
전체 시간: 3,922
