주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Cyber-shot DSC-HX1 Motherboard Replacement
필요한 것
  1. Sony Cyber-shot DSC-HX1 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
    댓글 쓰기
  2. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
    댓글 쓰기
  3. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX1 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
    댓글 쓰기
  4. Sony Cyber-shot DSC-HX1 Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX1 Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • Close the battery cover by pushing the cover inwards and sliding it to the left to allow more maneuverability when disassembling other parts of the camera.
    댓글 쓰기
  5. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the four #00 4.0 mm Phillips screws on the bottom of the camera.
    댓글 쓰기
  6. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two #00 4.0 mm Phillips screws shown on the side of the camera.
    댓글 쓰기
  7. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew the #00 4.0 mm Phillips screw on the top next to the view finder.
    댓글 쓰기
  8. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Pull open the plastic port covers on the side of the camera.
    • Remove the revealed #00 4.0 mm Phillips screw.
    댓글 쓰기
  9. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX1 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX1 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Lift the back LCD screen to reveal the back of the camera unit.
    • Unscrew the three #00 4.0 mm Phillips screws at the edge and center of the back camera unit.
    댓글 쓰기
  10. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX1 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX1 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, pry apart the bottom of the camera at the line between the four removed screws.
    • Place the camera on its lens and use the plastic opening tool to pry at the crack in the case on all four sides of the camera.
    • Apply moderate force to the backside of the camera enclosure until the two pieces separate.
    댓글 쓰기
  11. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX1 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the #00 4.0 mm Phillips screw and the #00 6.0 mm Phillips screw holding the motherboard to the front enclosure.
    • Disconnect the eight ribbon cables from their ports on the motherboard.
    댓글 쓰기
  12. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX1 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Detach the metal bracket from the enclosure by removing the two #00 4.0 mm Phillips screws.
    댓글 쓰기
  13. Sony Cyber-shot DSC-HX1 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX1 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • If you feel resistance from the board, double check all screws and cables have been removed to avoid damage.
    • Completely remove the motherboard by gently pulling the board away from the camera.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Brianna Greenlaw
회원 가입일: 04/06/15
1,316 평판
안내서 5개를 작성함
Cal Poly, Team 17-3, Forte Spring 2015 Cal Poly, Team 17-3, Forte Spring 2015 회원
CPSU-FORTE-S15S17G3
4 회원들
안내서 10개를 작성함
3가이드 댓글
Excellent partial disassembly overview!
Several suggestions to make this information more useful:
Provide Sony motherboard part number at top of page where there is a place to list parts.
Please list the size of the battery on the motherboard. My guess is the battery can be easily replaced once the battery type, size and voltage is known.
Distingush between location of 4.0 mm retaining screw and 6.0 mm retaining screw.
Highlight location of eight motherboard ribbon cable ports.
Detail how to disconnect ribbon cables without destroying motherboard cable ports.
Jim Fogle - 답글 공유
I am interested in changing the Mother Board but do not have any idea as to where I can purchase a new/unused replacement. Can anyone help me?
rcronin44 - 답글 공유
Replacement parts for the Sony DSC-HX1 digital cameras should be available from Encompass, https://sony.encompass.com/search/?model.... However, the website indicates the main board is no longer available. Sony also lists Union Electronics, https://www.ued.net/index.html, as a parts supplier but I am unable to find any parts on Union Electronics website. Of course one can always try eBay or Amazon.
The motherboard battery is soldered to the board so it can be dangerous to replace.
My camera sat without a rechargeable battery installed for a few months. The next time I used the camera the motherboard would not retain my settings. I found that leaving the replaceable battery installed for a few days recharged the motherboard battery. I now leave a rechargeable battery installed all the time and swap batteries about once a month when I’m not using the camera.
Jim Fogle - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 45
전체 시간: 4,281
