소개
To remove or replace the motherboard, you must disassemble a majority of the camera. Make sure to keep your screws separated and labeled.
필요한 것
Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
I want to know which typa of battery used in DSC -H1 don't cyber shot
Which type of battery used in DSC H1
Close the battery cover by pushing the cover inwards and sliding it to the left to allow more maneuverability when disassembling other parts of the camera.
Using the plastic opening tool, pry apart the bottom of the camera at the line between the four removed screws.
Place the camera on its lens and use the plastic opening tool to pry at the crack in the case on all four sides of the camera.
Apply moderate force to the backside of the camera enclosure until the two pieces separate.
Remove the #00 4.0 mm Phillips screw and the #00 6.0 mm Phillips screw holding the motherboard to the front enclosure.
Disconnect the eight ribbon cables from their ports on the motherboard.
There's one more screw to remove under the ribbon cable top left.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 3개
Excellent partial disassembly overview!
Several suggestions to make this information more useful:
Provide Sony motherboard part number at top of page where there is a place to list parts.
Please list the size of the battery on the motherboard. My guess is the battery can be easily replaced once the battery type, size and voltage is known.
Distingush between location of 4.0 mm retaining screw and 6.0 mm retaining screw.
Highlight location of eight motherboard ribbon cable ports.
Detail how to disconnect ribbon cables without destroying motherboard cable ports.
Replacement parts for the Sony DSC-HX1 digital cameras should be available from Encompass, https://sony.encompass.com/search/?model.... However, the website indicates the main board is no longer available. Sony also lists Union Electronics, https://www.ued.net/index.html, as a parts supplier but I am unable to find any parts on Union Electronics website. Of course one can always try eBay or Amazon.
The motherboard battery is soldered to the board so it can be dangerous to replace.
My camera sat without a rechargeable battery installed for a few months. The next time I used the camera the motherboard would not retain my settings. I found that leaving the replaceable battery installed for a few days recharged the motherboard battery. I now leave a rechargeable battery installed all the time and swap batteries about once a month when I’m not using the camera.
