이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
Close the battery cover by pushing the cover inwards and sliding it to the left to allow more maneuverability when disassembling other parts of the camera.
Unscrew the four #00 4.0 mm Phillips screws on the bottom of the camera.
Remove the two #00 4.0 mm Phillips screws shown on the side of the camera.
Unscrew the #00 4.0 mm Phillips screw on the top next to the view finder.
Pull open the plastic port covers on the side of the camera.
Remove the revealed #00 4.0 mm Phillips screw.
Lift the back LCD screen to reveal the back of the camera unit.
Unscrew the three #00 4.0 mm Phillips screws at the edge and center of the back camera unit.
Using the plastic opening tool, pry apart the bottom of the camera at the line between the four removed screws.
Place the camera on its lens and use the plastic opening tool to pry at the crack in the case on all four sides of the camera.
Apply moderate force to the backside of the camera enclosure until the two pieces separate.
Remove the #00 4.0 mm Phillips screw and the #00 6.0 mm Phillips screw holding the motherboard to the front enclosure.
Disconnect the eight ribbon cables from their ports on the motherboard.
Detach the metal bracket from the enclosure by removing the two #00 4.0 mm Phillips screws.
Completely remove the motherboard by gently pulling the board away from the camera.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 3개
Excellent partial disassembly overview!
Several suggestions to make this information more useful:
Provide Sony motherboard part number at top of page where there is a place to list parts.
Please list the size of the battery on the motherboard. My guess is the battery can be easily replaced once the battery type, size and voltage is known.
Distingush between location of 4.0 mm retaining screw and 6.0 mm retaining screw.
Highlight location of eight motherboard ribbon cable ports.
Detail how to disconnect ribbon cables without destroying motherboard cable ports.
Replacement parts for the Sony DSC-HX1 digital cameras should be available from Encompass, https://sony.encompass.com/search/?model.... However, the website indicates the main board is no longer available. Sony also lists Union Electronics, https://www.ued.net/index.html, as a parts supplier but I am unable to find any parts on Union Electronics website. Of course one can always try eBay or Amazon.
The motherboard battery is soldered to the board so it can be dangerous to replace.
My camera sat without a rechargeable battery installed for a few months. The next time I used the camera the motherboard would not retain my settings. I found that leaving the replaceable battery installed for a few days recharged the motherboard battery. I now leave a rechargeable battery installed all the time and swap batteries about once a month when I’m not using the camera.
