주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-HX100V Viewfinder Replacement
필요한 것
  1. Sony Cyber-shot DSC-HX100V Viewfinder Replacement, Viewfinder: 1 단계, 이미지 1개 중 1개
    • Make sure camera is turned off.
    • Press the ON/Off button to turn off the camera.
    • WARNING: Data may be lost if the camera remains on.
  2. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 2 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 2 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 2 단계, 이미지 3개 중 3개
    • Use the Phillips screwdriver size #00 to remove the 1.59mm #00 screws.
    • Remove 2 screws from the side of the camera.
    • Remove 4 screws on the bottom of the camera.
    • Remove 1 screw next to the eyepiece.
  3. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the screen back to reveal 2 hidden screws.
    • Remove the two 1.59mm #00 screws on the left with the Phillips #00 screwdriver.
  4. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the back panel of the camera upward.
    • Use a spudger to help pry open the back panel.
  5. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 5 단계, 이미지 1개 중 1개
    • Open the back panel to view the inside of the camera.
    • If the orange ribbon cable disconnects from its designated port, do not panic. The cable is easy to reinsert.
  6. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 6 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 6 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully pull out the the eyepiece.
    • Detach the orange ribbon cable that connects it to the green panel by carefully pulling outwards.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
DaQuawn
회원 가입일: 03/05/15
257 평판
안내서 2개를 작성함
Sam Houston State, Team 11-3, Blackburne Winter 2015 Sam Houston State, Team 11-3, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G3
3 회원들
안내서 8개를 작성함
1가이드 댓글
Thank you very much for the importent articles made for us. If I can please put , how to replace the flasher as well.
Satsara Gunaratne - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 1,133
