주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-HX20V LCD Replacement
필요한 것
  1. Sony Cyber-shot DSC-HX20V LCD Replacement, LCD: 1 단계, 이미지 1개 중 1개
    • Orient the device so the bottom is facing up, and the lens is facing you ("bottom view").
    • For further reference, consult the service manual. Link to service manual.
  2. Sony Cyber-shot DSC-HX20V LCD Replacement: 2 단계, 이미지 1개 중 1개
    • Remove these two black M1.4 X 3.5 Phillips head screws.
    • The third, unmarked screw does not need to be removed at this time.
  3. Sony Cyber-shot DSC-HX20V LCD Replacement: 3 단계, 이미지 1개 중 1개
    • Orient the device so the LCD is facing you, and the HDMI cover is facing up (left side view).
    • Remove these three black M1.4 X 3.5 Phillips head screws.
    • You must lift the HDMI cover to expose one of the screws.
  4. Sony Cyber-shot DSC-HX20V LCD Replacement: 4 단계, 이미지 1개 중 1개
    • Orient the device with the Wifi/GPS logo facing up ("right view").
  5. Sony Cyber-shot DSC-HX20V LCD Replacement: 5 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX20V LCD Replacement: 5 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX20V LCD Replacement: 5 단계, 이미지 3개 중 3개
    • Use a prying motion and a plastic opening tool to pry the side panel up.
    • Slide the panel downwards carefully, as these clips can be easy to break.
    • Areas under the squares are approximate locations of retaining claws, shown at right.
    • Be careful not to break any of the retaining clips as you pry up this panel.
    • An image from the Service Manual has been added, which shows this side cover should be slid down before being removed, not just pried up as shown in the first picture in this step.
  6. Sony Cyber-shot DSC-HX20V LCD Replacement: 6 단계, 이미지 1개 중 1개
    • After removing the panel, remove the two black M1.4 X 3.5 Phillips head screws.
  7. Sony Cyber-shot DSC-HX20V LCD Replacement: 7 단계, 이미지 1개 중 1개
    • Orient the device so that the LCD is facing you ("back view").
  8. Sony Cyber-shot DSC-HX20V LCD Replacement: 8 단계, 이미지 1개 중 1개
    • Use the plastic opening tool with a prying motion, going between the case and the LCD, from the middle of the LCD to the right of the device, undoing the claws retaining the back.
    • When replacing the back cover of the device, ensure the flash module is UP.
    • The back cover should come off easily but you might hear light snapping or popping.
    • The rotary wheel and button are not secured. They will come loose when the back cover is removed. Set them aside for reassembly
  9. Sony Cyber-shot DSC-HX20V LCD Replacement: 9 단계, 이미지 1개 중 1개
    • Unhook the small printed circuit board by gently pressing the board towards the top of the device and lifting up.
    • Note a ribbon cable should be attached at the top. This does not need to be disconnected yet.
  10. Sony Cyber-shot DSC-HX20V LCD Replacement: 10 단계, 이미지 1개 중 1개
    • Using a plastic opening tool remove the black LCD retainer clip to the right of LCD.
    • Note the orientation of the black LCD retaining clip and how it comes out of the camera.
    • If in doubt, consult the service manual. (Pages 25-27) Click to continue to the service manual. This has a reference number of 3 in the linked diagram.
  11. Sony Cyber-shot DSC-HX20V LCD Replacement: 11 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to gently lift the LCD from the device
    • The LCD should be attached to a ribbon cable
  12. Sony Cyber-shot DSC-HX20V LCD Replacement: 12 단계, 이미지 1개 중 1개
    • Using the plastic opening tool to lift the black retaining clip up to disengage the ribbon cable. Then gently pull the ribbon cable to remove.
    • Be careful to not damage the cable.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Zacharias Merriam
회원 가입일: 04/08/15
380 평판
안내서 1개를 작성함
2가이드 댓글
This tutorial is great, but I think it misses one fundamental part out. The LCD screen you are removing is actually clipped into a backlight panel. Some LCD screens that you can buy as replacements on eBay don't actually come with the backlight panel installed and it can be very difficult to remove the backlight panel from your old LCD screen to your new one if your new one didn't come with one.
To anyone who is reading this tutorial, when buying a replacement LCD for your camera, always make sure that it comes with a Backlight panel too. Mine didn't so I can't really use it and I've had to order one from China on eBay. The description of the LCD screen on eBay should include the fact that the screen comes with a backlight. Watch this video for more info on backlight panels: https://www.youtube.com/watch?v=pWirT0cK...
Tom Southworth - 답글
Thanks dude - You saved my device with this usefull tutorial
Daniel Evens
EVENS DANIEL - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 18
지난 30일: 75
전체 시간: 4,754
